Soil Percalation Rate & Pressure At Depth
I'm working on a small house on a confined lot. We have some drains in a walkout along the side the house and I would like to determine the viability of draining them to a dry-well that is 9 feet below the ground at the back of the property (the basement is 9 feet deep and the dry-well needs to below the footer).
The house is on a hill and well above the water table so that isn't an issue.
I'm concerned that after several days of heavy rainfall water will reach the dry-well and fill it up rendering the drains useless.
I'm attempting to calculate the rate at which surface water will percolate down and into the dry-well. and how much volume I can expect.
I know the water will come down in a cone to the void, but I'm not sure how to account for the fall off of that cone. Furthermore I'm concerned that as we go deeper under ground pressure will build and increase the rate at which water is being pushed into the dry-well.
Are there any examples of how I might go about calculating this, and is my concern about the pressure valid?
Note: I have my percolation rate already figure out. I'm just confused on how to quantify the rate at which that water will percolate into a void deep underground.
RE: Soil Percalation Rate & Pressure At Depth
You indicate that you already have the percolation rate figured out. How did you do this? Was it field tested? If tested, was it done at a depth of 9 feet?
Other questions that come to mind include:
1. how did you figure the amount of water that will reach the dry well?
2. what happens if there is more rain than you expect? Do you get water in the basement? How much damage/trouble does water in the basement mean for you?
At a minimum, I would install a sump pump to handle the water if the dry well can't keep up.
Mike Lambert
I've been reading about Darcy’s Law. I figured that would be part of the calculationg as it takes into account horizontal and vertical movment.
