Friction grip collar on CHS
Typically we use welded shear tabs on CHS columns which we use to connect beams, braces etc.
For various reasons which I won't get into, some of my colleagues are looking to move away from this detail, and instead use something similar to a friction collars (custom part) and have the shear tab welded to it. I have been asked to provide an opinion on this new detail.
They have friction collars for concrete (see links below), however I have never seen anything like this for steel. I have no experience with the ones for concrete.
http://www.proscaffna.com/frictioncollar.php
http://www.cffeco.com/#!friction-collars/c112d
At first glance, this type of connection seems like a bad idea because of unknowns like the actual coefficient of friction between the surfaces, how much of the collar is actually in contact with the CHS wall due to potential fabrication errors and just the general concept of having a connection held up entirely by friction.
Does anyone have any experience with this type of connection (either with steel or concrete) and how it actually works in practice? Are my concerns entirely valid?
RE: Friction grip collar on CHS
That's my general opinion as well, but I understand what my colleagues are trying to achieve in terms of developing an alternative connection detail. The general idea is that we have a large number of these columns that need to be produced, and each of them will have multiple shear tabs welded to them at different orientations - resulting in a lot of unique parts that require their own shop drawings.
The intent is to reduce the number of unique parts down to 2, one for the regular CHS, and one for the collar with a shear tab welded to it. Then multiple collars could be installed on the CHS columns and oriented in the field.
Buggar,
These will likely be subject to wind and seismic forces.
However, friction based connections are typically required in situations where there is load reversal. These are not assumed to experience any sort of reduction (or elimination) of the frictional resistance when they experience load reversal, at least not at service load levels.
Is this because in this particular scenario, the faying surfaces providing the frictional resistance would be away from the fasteners? Do you have a reference in mind that I could look into that sheds some light on this?
You could weld shear tabs to the columns at 0,120, and 240 and then bolt a part between tabs to pick up the odd angle connections. I did something similar for some utility poles that have a lot of possible attachments.
Unless you're planning on providing some sort of fail-safe backup I wouldn't be doing this.
What's the application anyway? What's the result of the connection failing?
Unfortunately, I know of no standard guidance document. They are always designed from first principles.
http://www.google.co.uk/url?sa=t&rct=j&q=&...
Field welding is likely out. The parts are galvanized, so any welding should preferably be done in the shop.
XR250,
That might be the ideal solution and should be easy enough to design and implement.
jayrod12,
The collars with welded shear tabs would connect to beams or members that support small platforms for pedestrian traffic. Failure of that connection would ultimately lead to the collapse of that platform with the potential for injury to the people standing on the platform. I think having a welded tab as XR250 suggested might be a workable solution.
Ussuri,
Thanks for the document. I'll be able to review in more detail later.
Another option might be to simply install galvanized blind bolts in field drilled holes.
Using blind bolts was my first suggestion when my colleagues and I discussed this. Their concern is with field drilling the holes and damaging the galvanized coatings layer which could lead to the onset of corrosion. Although they could always touch up those areas in the field to avoid any potential problems.
