Violation of EN50160 Std.
Hello
I am working in a utility company. One of our clients ives in one out of 20 townhouses. All houses have 6 kW PV´s 3-ph. installed. The problem is that the client is experiencing problems charging the electrical vehicle. From measurements we have concluded that the problem is caused by the amountof PV´s, not the single unit itself. The single PV respects the std. EN61000-3-2 with regards to harmonics currents - (in terms of absolute values).
At the moment we are examinining voltage quality at the point of common coupling for all houses at which point we are responsible as a utility company. After a week a report can be made and we can observe whether EN50160 is fulfilled or not. Now my question is as follows:
In case EN50160 are not passed who is the responsible party under the assumption that the sum of installed PV´s are the key to the problem. I have thouroughly read EN50160 but I am not able to find any answer in this.
B.R. Hans-Henrik.
B.R. Hans-Henrik.
RE: Violation of EN50160 Std.
Marmite
