Reuse library placement.
Hi All,
First when I used the Reuse Library it asks for "Select Origin", but since a while the placement is using "By Constraints".
When I pull a part into the assembly it shows shortly the same screen as "Add Component" where I can select "Select Origin", but this screen is showing to short to select it.
I tried to use "Select Origin" by "Add Component" in the hope it would remember this setting also for the "Reuse Library" but sadly it doesn't.
Anyone a idea how i could use "Select Origin" at "Placement" again in the "Reuse Library"?
Thanks in advance,
Tjeerd
Using NX 8.0 and Teamcenter 8 on Windows 7 (64)
RE: Reuse library placement.
Did you try setting it in Customer Defaults?
Assemblies - General - Component Operations.
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP Zbook15
Intel(R) Core(TM) i7-4800MQ
CPU @ 2.70 GHz Win7 64b
Nvidia K1100M 2048 MB DDR5
Thanks Nutace, that solved my problem.
I already thought that there was such an setting, but I didn't know exactly where.
