Creep data for glass filled nylon
Please can anyone tell me where I can find creep data for glass filled nylon in the region of 50% filled?
Thanks in advance.
Thanks in advance.
RE: Creep data for glass filled nylon
http://www.williamandrew.com/titles/030.html
Other references that may be of use can be obtained from the SPE bookstore using the following link:
http://www.4spe.org/bookstore/
You should be able to obtain this type of data from your resin vendor. I am not familiar with any standard 50% glass-filled nylons, so this may be a compounded grade from someone like LNP or RTP. Either way, you need to start by reviewing the data that they already have. If none exists, make them perform the necessary testing. Nylon producers like DuPont, Ticona, etc. have labs and personnel that are responsible for materials characterization so that customer's requirements such as yours' can be met.
then get the data from a PA supplier e.g ticona, and there you go!
Campus is a database merging program set up by the leading material suppliers. Each supplier measures their plastic materials to a standarised (ISO) method. They make this data available as a downloadable package, which is mergable in the Campus Program. Campusdata from the suppliers is usually available on their websites.
The Campus program merges and organises all data files from the different material suppliers, making searching easier.
The Campous data includes usually also creep diagrams.
Maybe some work to get the program and the data, but certainly worth while if you need data more often.
Good luck.
