No. of decimals in MAWP
Good morning friends....
I have one query regarding no. of decimals in MAWP of vessel as below:
In PV Elite, MAWP of vessel is specified till 3 decimals.
Should we take any of the unit systems, commonly used in the world, none of the pressure gauge can measure pressure up to 3rd decimal.
In other word, measuring pressure to 3rd decimal place is not practical.
Hence, a question comes to mind, why to mention MAWP which can’t be measured.
Other way round, no. of decimals in MAWP shall be same as those in design pressure, specified by user, which sounds logical also.
Request your review / suggestions.
RE: No. of decimals in MAWP
David Simpson, PE
MuleShoe Engineering
In questions of science, the authority of a thousand is not worth the humble reasoning of a single individual. Galileo Galilei, Italian Physicist
I could see the use of decimals as opening up the potential for misinterpretation. For example, if someone glances at a nameplate that states 153.1 psi and for one reason or another doesn't notice the decimal (worn out/bad lighting/dirty/etc...), they might think they can pressurize the vessel to 1531 psi, creating a very dangerous situation.
"Hence, a question comes to mind, why to mention MAWP which can’t be measured."
SilverMani, it's just software. It does the calculating for you, not the thinking :)
Mike
What do you think?
r6155
I am also in agreement with what u said.
But many designer simply follows MAWP whatever software shows.
e. g. For specified design pressure of 400 psi, if calculated MAWP is 405.650 psi, same has been mentioned on nameplate.
I strongly feel that it should be 405 psi only.
We are going absolutely crazy today, with out approach to real engineering of products and systems. Just because the computer programs which we rely on today to do all of our engineering thinking for us can/do calc. results to eight or ten decimal places does not mean that we can really design to that accuracy. We just don’t know enough. We are deceiving ourselves if we even think that for a second. The way we have modeled the system or structure incorrectly/inaccurately will cause a 10 or 15% error in the results. Imagine how vessel pressures or component stresses change every few minutes during the process. Imagine that some minor stress raiser, a weld termination or a poor fab. detail, something like that can raise the local stress by 50%, so what the hell are we trying to calc. operating pressure or vessel stresses to anything finer that 10 or 20 or 30 psi? The important thing, that we as experienced engineers should be doing is designing and watching for situations which make the whole system go crazy or blow up. Good clean detailing, good clean fabrication on the gross scale is far more important than a .5psi variation in stress or pressure.
Perhaps this is one issue which distinguishes a designer from an engineer.
A well-grounded engineer recognizes the significance of significant figures. I maintain that in most pressure vessel applications, the notion of more than 3 sig. fig.'s for most values is fantasy once the steel is installed on site. Those who would argue for 8 sig. fig. weights are doomed to change the weight of the vessel every time a bird craps on it.
The material spec may well call out a minimum figure quoted to 2 significant figures, but in some cases, even the first digit can be a bit suck it and see when you look at achieved properties.
A.
Agreed. But for most loadings, we can reasonably use two or three significant figure values and pass a red face test. The question here is reporting MAWP to the thousandth of a psi (in a plant which uses analog gages) or weight to the 10th of an ounce.
zeusfaber-
Also agreed... but with MTR values only being truly useful in a FFS environment, the actual UTS and YS are of less interest.
Bottom line, and circling back to the OP's query, I prefer 3 sig. figs for MAWP reporting, in some high pressure cases 4 may make sense. But for the vessels that I deal with, 8 sig. fig's on an MAWP is not sensible. When I see 8 sig. fig's, it is perceived by me to be a negative indicator of the engineer / designer who is signing off on the document. Don't get me wrong here, a "negative indicator" doesn't mean "this sucks" just that they haven't bothered to consider what they are reporting. And I recognize that others' perceptions can differ. That's what makes perception special!
