Duplicating values from design report for sheet metal screws
I have a question regarding calculating pull over capacities for TEKS screws. According to ESR-3223, Table 3 - Allowable Tensile Pull-Over Loads, the allowable tensile pull-over load for a #12-14 HWH screwed into an 0.048 inch thick steel sheet equals 619 lbf. However, according to AISI S100-07 Section E.4.4.2, the pull over load, Pnov/omega, is as follows:
Pnov = 1.5*t1*d’w*Fu1 where
t1 = 0.048 in.
d’w = dh = 0.4 in. Case (B)
Fu1 = 58 ksi (as indicated in footnote 3 of ESR 3223, table 3)
Omega = 3
Therefore,
Pnov/Omega = (1.5 )*(0.048 in.)*(0.4 in.)*(58 ksi.)*(1000 lbf/k)/3 = 578 lbf
This is not equal to 619 lbf. Now according to ESR-3223:
“ITW Buildex TEKS Select Structural Fasteners are recognized for use in engineered connections of cold-formed steel construction. Design of the connections must comply with Section E4 of AISI S100."
I therefore do not understand why the values are not matching. Please explain to me why. Thanks for your consideration.
t1 = 0.048 in.
Fu1
Omega = 3
Therefore,
RE: Duplicating values from design report for sheet metal screws
I would guess that AISI S100 has alternate methods for values based on testing that vary from the equations. I haven't read that in AISI, just my hunch.
So, in summary, you are using calculations, whereas they are using testing. Or so is my best guess.
...and as njlutzwe noted, you are comparing tested values to calculated values....there will almost always be a difference.
