NX face selection
3
NX face selection
NX face selection
how can I change the rectangle selection that only the visible faces will be selected?
I will not select the faces behind other faces...
It is about that I want to change the color of an assembly, but only the color of the outer faces. I don't want to touch the parts of inside...
(so I could define which faces of which parts are visible from outside)
Any advice? :)
Nx version: 8.5
RE: NX face selection
Ah thank you:)
cheers
