Cannot export to DWG
Hi! I'm having a problem when exporting drawings (.slddwr) to DWG. Whenever I try to save-as a drawing as DWG, y seems to be working, but it does not generate any output files. Same thing happends with DXF, and when running batch conversions via Task Scheduler. Ideas? Solutions?
RE: Cannot export to DWG
Try the version your exporting to. Had a similar issue and when I changed the "R" version in the export option it fixed the issue and the vendor could open the file then.
Scott Baugh, CSWP pc2
Gryphon Environmental
www.2gryphon.com
Quote:
"If it's not broke, Don't fix it!"
