SAP2000 Section Cut
SAP2000 Section Cut
Hi, I am modeling a large masonry building with shell (50x50 cm approximately),
I created a lot of section cut ( about 2000 ) with excel spreadsheet.
After analyzing the model I exported tables showing the resultant stresses for each section cut.
I would like to know if there is a way to export a table showing:
-) the total length of the section cut
-) the thickness of the sectioned shell
thanks to all and sorry for my english.
RE: SAP2000 Section Cut
Of course the thickness is again relevant to the plane dimension you defined in Excel.
Think of section cut as plane cutting through elements (shell, frame and etc.) whichp integrated the forces in that cut region.
Shoot for the Moon, even if U miss, U still land among Stars!
I forget the table for the thickness, try to see from property definition table, i think is it.
