Problem finding a cam follower roller bearing with the right dimensions STO8ZZ Torrington V.50 Czec
Hi All
We have to replace a roller bearing with the code :
STO8ZZ Torrington V.50 Czech
From <http://webshop.abfbearings.com/Bearing/STO8ZZTORSU...;
On it, but the strange thing is that the catalogues , even the old ones, indicate the width B = 9.8 mm , while this one has the outer diameter : D = 24 mm, B=14mm , and d= 6.3 mm !!! The machine is very old and this one mounted is actually replaced with the original , while the original , had the same width , and the outside Dia is D=19 mm , anyway not even this one exist in the catalogue , what do you advice ?
RE: Problem finding a cam follower roller bearing with the right dimensions STO8ZZ Torrington V.50 Czec
So you have 2 bearings to compare. Old and older ?
page 163.
