4063 Laser gas or PSU alarm
Hi friends,
I have AMADA FO3015NT Laser machine,
i found in last week : 4063 Laser gas or PSU alarm so i contact AMADA and the send fanuc Engineer they give me this report.
Date: 21.06.16
Visited for 4063 Laser gas or PSU alarm. Customer observed fire from PSU-1 at time of high volt ready.
Visited and cold check PSU-1. Found not ok during cold check. Check matching Box-1 and found burn mark
on main bus bar.
PSU-3 already swapped to PSU-1 by AMADA. Today fitted matching Box-4 to 1 and taken trial. Found DCI3 LED
on during SEQ26.
Confirm problem with PSU-1, PSU-3 and Matching Box-1. Problem is occurred after heavy power fluctuation
and customer bypassed UPS.
Request customer to check power condition and earthing. Right now 3-phase power check and found 220VAC
balance.
Date: 28.06.16
Today visited and fitted new PSU and matching box at PSU-1 MB-1. Done base discharge and rated
power PSU tuning.
Fitted new PSU at PSU-3, taken trial and found during base discharge adjustment DCI3 found glow.
Checked MB-3 and found 1 coil is become black from bottom. Customer’s MB1 all coils are ok only
arc found at bus bar. Replaced bus bar from MB3 to MB1 and fitted MB1 at MB-3 place.
Taken trial and found at PSU-3 base discharge adjustment found completed. During rated power
adjustment fund DCi1 and DCi2 LED glow together. Also MCB for PSU-3 found tripped.
Checked PSU-3 and found sort at input 3-phase terminal. Confirm that Fanuc PSU which is fitted to
machine is found faulty now.
We will arrange one more set of matching box and PSU and visit again. Right now bypassed PSU3
hand over machine for production.
Finally i want to know that if DCI 3 LED found in any PSU that means its foulty???.
We should replace it??
It can damage Match box??
Date: 21.06.16
on main bus bar.
on during SEQ26.
balance.
Date: 28.06.16
power PSU tuning.
