Select Region Boundary Curves from multiple sketches?
I want to create an Extrude feature using curves from multiple sketches that form the boundary I want to use for the extrude. It seems this is not possible, I can only select regions from curves from the same sketch.
In the attached image I want to select the innermost triangle boundary (the small straight line belongs on a different sketch than the other curves), but NX is not allowing me to do so.
Is this not possible?
Thanks.
NX10.0 Win8.1 64bit i7-3770K 16GB QuadroK2200
RE: Select Region Boundary Curves from multiple sketches?
Seems to be so, but works fine if project all the needed curves on the one sketch.
If I understand correctly, you should be able to toggle on "stop at intersection", and make sure you are selecting "curves", and not "feature curves" in your selection filter. I use curves from different sketches all the time.
-Dave
NX 9, Teamcenter 10
Are you trying to do this while the part is a work part within an assembly? I have had some issues when trying to pick curves from different sketches while the part is a work part in the assembly. Try making the part the displayed part and trying it again. I doubt that this is the issue but worth trying.
Gunman, yes that's an option which works.
Sorry, i suggested that you wanted to use a Region Boundary Curves option in Extrude to select the innermost boundary in sketch.
