impact results - UHT material´s welding
Dear colleagues,
I hope this message finds all you well
Project: ASME VIII- Pressure vessel - material ASME SA517 Gr B. Thickness 9,5 mm.
I have to qualify a WPS for welding ASME SA517 - B with impact requirements at -40 C,
Also is required PWHT, and my first results of impact test @-40C of test plate were very low. (lateral expansion less than 0,2mm and energy less than 20J)
The declared Values of certificate of consumable is 75J @ -73C !!!
Can the presence of PWHT changes so much the values of impact? (certificate´s value is "as welded" and my results is "after PWHT".
Any help will be very useful.
Thanks a lot,
Fernando Lescovar Neto
Thanks a lot,
RE: impact results - UHT material´s welding
