FEMAP V11.3: Interactive Mesh Refine
Hello!,
This new command of FEMAP V11.3 allows you to dynamically “highlight” 2-D shell elements to refine using one of two patterns:
• 1 to 4: each original quad element split into four QUAD elements.
• 1 to 9: each original quad element split into nine QUAD elements.
Any elements surrounding the “refined elements” will be automatically split using appropriate “transition patterns” to maintain connectivity between the “newly refined mesh” and the “original mesh”. As the elements are “highlighted”, a preview of the “refined mesh” and “transition mesh” will be “painted” on the original elements. Once you are satisfied with the mesh refinement, click OK to update the original mesh.
In addition, there is an option to split shell elements in two halves or into thirds by using specified vector to “split along”.
Finally, any line elements sharing nodes with a refined or modified shell element will also be split appropriately.
Enjoy!.
Best regards,
Blas.
Blas Molero Hidalgo
Ingeniero Industrial
Director
IBERISA
48004 BILBAO (SPAIN)
WEB: http://www.iberisa.com
Blog de FEMAP & NX Nastran: http://iberisa.wordpress.com/
Enjoy!.
Best regards,
Blas.
Blas Molero Hidalgo
Director
IBERISA
