Closed head foam water sprinkler
Use Manufacturer?
RE: Closed head foam water sprinkler
Chemguard and Tyco are often together. I've used them in private and military hangars.
This stuff is quite specialized. If you mess up, the mistakes are very costly.
Travis Mack
MFP Design, LLC
www.mfpdesign.com
"Follow" us at https://www.facebook.com/pages/MFP-Design-LLC/9221...
I dont know English very well
Travis Mack
MFP Design, LLC
www.mfpdesign.com
YOU MAY ONLY USE MY of which company? WHICH MODEL?
TÔI ĐÃ CÓ BẢN VẼ THIẾT KẾ DO BÊN KHÁC THIẾT KẾ, TÔI MUỐN MUA ĐẦU PHUN FOAM KIỂU ĐÓNG,TRƯỚC ĐÂY TÔI ĐÃ DÙNG FOAM CHAMBER, OPEN HEAD NHƯNG CHƯA DÙNG CLOSE HEAD BAO GIỜ.
CÁC BẠN CÓ THỂ CHỈ CHO TÔI DÙNG CỦA HÃNG NÀO? MODEL NÀO?
THANKS!
If you use a Buckeye Foam system then you will use a Reliable automatic sprinkler because a Reliable sprinkler is what is specifically listed to be used with a Buckeye foam system.
For a Chemguard system you will use a Tyco sprinkler because the Tyco sprinkler is what is listed for use with the Chemguard system.
What you do is select your foam system first and then apply the appropriate sprinkler that is listed to be used with that particular brand of foam system.
