Help with telescopic assembly
So I would use some help settling for a design here.
http://files.engineering.com/getfile.aspx?folder=3...
I was able to acquire telescoping tubing, but now i have to install the stops for each section, i've researched a bunch of designs basically looking for the one that will give me most stability, when extending and retracting but also with the least backlash.
I am working with about 1/16 gap on each side.
http://files.engineering.com/getfile.aspx?folder=c...
Thanks in advance!
Thanks in advance!
RE: Help with telescopic assembly
...but...
... you didn't tell me if you can weld that material...
... you didn't tell me what you are using this for...
... what load / stiffness do you need?
... so more information about what you are trying to make would be helpful.
STF
https://drive.google.com/open?id=1qZ3gs6F6-TgUk6qG...
The telescope is part of a small scale prototype, serves as an extension of a vehicle which would be meant for 3D printing.
On the end of the telescope I will have a robotic arm which will serve as an extruder but also as a way to perform more tasks to the print.
The end of the telescope will weigh less than half a kg. However, the reluctance in my approach is somewhat extreme since I need the motion to be fairly stable, stable enough to lay a decent line.
I can probably manage to weld or braze the aluminium, i like your idea. I might end up doing that and just welding inner stops for retraction. Then im thinking about a way to install shims to close the 1/16 gap, i saw some friction-less tape during my last sight-seeing at a hardware store, might be a good way to do it too.
