Odd behaviour in NX 10.0.2
Recently we updated to NX 10.0.2 (it was 10.0.1 before), and now when we create new item in NX integration, we suddenly get a new "required" field called "partno". We also noticed that the item id is now referred as DB_PART_NO (which is not like it was before)
This field can be automatically filled when doing auto-naming, but not when importing assembly into teamcenter - it appears on each line and requires manual input
I also noticed that the secondary attributes menu has this new field
I couldn't find anything wrong in the customer defaults / site settings.
How can we fix this?
Thank you
Thank you
