Duplex 2205 Tubesheets
I have 2" thick duplex stainless tubesheets with duplex (S31803) 3/4" o.d. straight tubes, I'm being forced into impact testing to -50 deg. F.
for the tubesheets, and so my question is: Is there any solution that would let me out of this impact testing requirement? Any exemption?
From what I've read about 2205 duplex is that it's hard to exempt.
RE: Duplex 2205 Tubesheets
What is your code of construction?
Per ASME VIII-1, you must impact test.
See section UHA-51(d)(3)(a). The only exemption available is for 3/8" and thinner if you are at a temperature of -20°F and warmer.
Cheers,
This is why you often see 2205 tubes put into austenitic tube sheets.
I hope that your raw material was tested to A923, that is a -40 impact test.
If your application requires -50F testing, and at -50F you still exceed the energy requirements of A923 then you only have to do the one set of tests.
