Ug NX9 Part name clash using G.M. toolkit
Ever since Nx9 came about, when modeling/surfacing a new work part, there seems to be an issue with said work part grabbing features from a used product file in which it stores unknown features from the product file used containing a link to the part name somewhere within the work part. When re-opening said work part and trying to add component (part used for development), you are now given a "name would clash with part already known in the session", yet no part file with that name is loaded. We have tried parameters, part clean-up(s), what we feel is every option in "utilities", etc.. Does anyone have a thought on where to look to possibly strip the offending feature the work part may have grabbed which constantly seems to cause name clashes upon adding as a component?
RE: Ug NX9 Part name clash using G.M. toolkit
Tim Flater
NX Designer
NX 9.0.3.4 Win7 Enterprise x64 SP1
Intel Core i7 2.5GHz 16GB RAM
4GB NVIDIA Quadro K3100M
Wave link feature part references?
When trying to start NX by itself without the GM stuff(Did not touch the NX install during the GM upgrade, BTW) I get:
The procedure entry point
?MakeMwGougeChecker@DemandLoader@Cam@UGS@@SAPEAVIPat
hChecker@23@PEAVOPR@3@HP6AHPEBDPEAX_N@Z2N@Z could not
be located in the dynamic link libcamsdemand.dll.
Tim Flater
NX Designer
