Sprinkler number.
Sprinkler number.
What if i have an elongated room. with an area of 517 sq.ft. its classified as light hazard. in light hazard the sprinkler have 225 sq.ft of protection so, 517/225 = 2.297
use: 3 sprinkler in the room. but since its elongated should i use 6 sprinkler to protect the room? the dimension of the room is 29.19 ft x 17.71 ft. thanks in advance.
RE: Sprinkler number.
Since under 800 sq ft
In the 29' dimension you need 2 sprinklers. In the 17' dimension you need 2 sprinklers
4 should cover.
Travis Mack
MFP Design, LLC
www.mfpdesign.com
"Follow" us at https://www.facebook.com/pages/MFP-Design-LLC/9221...
