Hi this is my question: what's th
what's the meaning of "The CET for systems constructed to ASME B31.3 is defined as the lowest metal temperature at which a component will be subject to either 30 percent of the maximum allowable working pressure (MAWP) at ambient temperature or a combined total longitudinal stress due to pressure, weight effects, and displacement strains that do not exceed 55.2 MPa (8 ksi). The CET for piping is determined from the anticipated process and atmospheric conditions."?
How do you define the CET of a CS line of liquified BUTANE?
RE: Hi this is my question: what's th
Good luck,
Latexman
To a ChE, the glass is always full - 1/2 air and 1/2 water.
Good luck,
Latexman
