NASTRAN SOL 106 Output
Hello!
I've got a quick question about SOL 106 that I am using for non linear buckling.
I've got 10 load cases (10,20,30,40,50,60,70,80,90,100 bar pressure cases), and I would like to predict buckling for that.
The output gives me ALPHA values, usually not far from eigenvalues. From this ALPHA I can calculate Pcr, from the incremental load case.
But I don't know how to interpret these results! What does that mean exactly? For each load case I have a Pcr, so how do I known I have buckling?
It's a bit confusing, compared to linear buckling where I have a set of buckling load factors for the given load. But here, as the load is incremental, it looks like buckling will occur at each load step.
Hope someone can clarify that!!
cheers
cheers
RE: NASTRAN SOL 106 Output
Well, if I want to know if buckling will occur at 100bar, I have 10 load cases, up to 100 bar.
But from the f06 file; there is an ALPHA value for each of the load cases, so it seems like buckling is predicted for each case!!
Also, looking at the displacement of the grid point; nastran gives me the eigenvector displacements which are 10E-18 so zero...
How can I get the actual displacement so that I can plot F vs displacement and visualize buckling?
Thanks!
