Wood Header design Load
Under what consideration (IBC 2308.9.5-6 header) span reduces, when it's two floors. In my understanding floor loads ( gravity) are not accumulative on header beams but trimmer and king studs ( when nailed together).
Did they consider additional load from upper floor designing header ? If, why?
Thanks!
RE: Wood Header design Load
Quote (KB2016)
I believe so and suspect it is because they are not assuming that the header supports will stack.
And what if you have a window or door in the main floor that doesn't exist in the second floor.
You can't argue with forces. Just go with the flow and do the design.
Mike McCann, PE, SE (WA)
