insulated copper pipe for potable water
Am just looking for some infomation about copper pipe. If i was to choose an insulated copper pipe for potable water, shall it be WRAS approved? I think the WRAS certifcation is only for the fittings whereas for its intended use as potable water then it shall comply to BS EN 1057. Is that sufficient or am i wrong in saying that buying a copper pipe complying with BS EN 1057, that doesn't mean its intended use is for potable water. Can anybody help me on that issue?
RE: insulated copper pipe for potable water
