Welding galv. ASTM A53 gr. B handrail?
A project specifies galvanized ASTM A53 grade B pipe for handrail. Must this handrail be welded with GMAW (mig) or can SMAW (stick) be used?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Welding galv. ASTM A53 gr. B handrail?
I would use mig or tig either way, since you'll be touching up any splatter, the welder will thank you too, since galv is already so crappy to work with.
Are you bidding work or executing?
This is not how handrails are to be fabbed.
No, management frowns on double posting. Cross-posting, i.e. putting a thread in the other forum referencing this one (or vice versa) is actually encouraged.
