How to make Taper in Dia 2.5 mm silver pin. required 15mm length of pin from roll.
Any one can help this from Roll I need to manufacture each 15mm length pin with starting Taper for 3to4 mm. Any manufacturing method profile forming. I tried multiple dies
RE: How to make Taper in Dia 2.5 mm silver pin. required 15mm length of pin from roll.
www.tynevalleyplastics.co.uk
Politicians like to panic, they need activity. It is their substitute for achievement.
http://www.engineersedge.com/mechanical,045toleran...
What was the problem you had cold forming the pins using progressive dies? Was it a dimensional/form tolerance issue?
Try talking to these guys: https://www.andersonmfg.com/cold-forming-services....
je suis charlie
