reinstallation of siemens nx
I have a workstation with a borrowed NX license. There is a function which is not working and because of this I would like to reinstall NX.
How to backup the borrowed license? What is the best way to do this without loosing the license?
RE: reinstallation of siemens nx
What is it that doesn't work ?
Are you sure you did borrow the license for that option ?
Tomas
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP Zbook15
Intel(R) Core(TM) i7-4800MQ
CPU @ 2.70 GHz Win7 64b
Nvidia K1100M 2048 MB DDR5
A borrowed license is intended to be used when, for example, you leave the office and have no network connection to your license server, or similar situations.
If you have network connection to the license server , you do not need the borrow option.
2) the logfile can be found : Pre -NX9 under Help - Log file, NX9 and later : File - Help - log file
Immediately after you have tried this function that doesn't work, open the log file, the last lines in the log file will give information on what's wrong.- If its a "crash" or a license issue.
It is fully possible that this computer doesn't have the needed license borrowed.
3) can you tell more on exactly what button you try that doesn't work ?
Tomas
