CONDENSATE RECOVERY SYSTEM
Hello Everyone
I have a pegging steam line with 40 bar steam pressure, and i installed two steam traps in parallel to drain condensate from it. my condensate load is 120 kg/hr. both steam trap outlets are connected to one collecting tank open to atmosphere. but after installation i saw that both steam traps are low temperature and not at all discharging condensate. when i open the bypass valve all the condensate goes out from bypass only and steam traps remain blocked. i checked the capacity of steam traps and it was in the range still i am not understanding what went wrong, please suggest me any remedy...
RE: CONDENSATE RECOVERY SYSTEM
What have you investigated so far?
what are the pressures / temperatures / flows?
As mentioned above, I would put good money the two traps you currently have installed in parallel are not rated for that high differential pressure and are remaining shut.
I would even look into a bi-metallic trap if your looking for more longevity before having to service the traps again.
« Rien ne se perd, rien ne se crée : tout se transforme ».
— Antoine Laurent de Lavoisier (1743-1794)
