Does it make sense to make a tolerance that does not exist in the tolerance tables ?
Hi All
I am trying to use the tolerance standards more appropriately and with more sense, but regarding to the work we do , that is for the different machines that we have , we happen very often to be obliged to replace a broken piece. for example I see that sometimes tolerances like -+0.01 are chosen , that for fit and precise running, I did not find any, but it seems that they do that by experience or feeling ?! is there any way to reason that if such a tight tolerance is not ok and for example a H7/g6 is a better one?
RE: Does it make sense to make a tolerance that does not exist in the tolerance tables ?
Chris, CSWP
SolidWorks '16
ctophers home
SolidWorks Legion
Certainly on any interference fit, the insertion forces, induced stress in the mated parts, different material properties and other factors may work against simply using the standard limit & fit tables without any extra thought.
In theory using the standard fits should conform to available tooling, ground shafts, mating parts... but varies in practice.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
