Rollover Suggestion?
This post is the sequel to the post "Hurricane Ties at 45-Degree Angle"
RE: The sketch at "Hurricane Ties at 45-Degree Angle"
Any suggestions to prevent rollover for the wood purlins on wood top plates?
I've used Simpson NCA and TB bridging in shallower end-wall situations, 45-degrees concerns me more.
I've considered: 1) solid blocking with necessary nailing; 2) a steel angle, similar to Simpson HGA10...
Any other suggestions?
Thank you all!
Thank you all!
RE: Rollover Suggestion?
Then...
Laugh on the inside that most engineers aren't considering that.
Cry that Architects get to design wood structures without understanding load paths like this.
Sleep well at night knowing you are doing the right thing.
Wait for the code officials to get a seminar that explains this type of detailing.
Watch your phone light up with calls because you're the only engineer that considers load path.
