Grade Beam Question
Grade Beam Question
I have seen grade beams directly on piles with the bottom of the beam below frost line (say 42" below grade) and, Grade beams that are supported on 2'x2'x18" pile caps. It that case, the bottom of the grade beam is only 18" or so below grade. I like to see what the general consensus is out there. I prefer the grade beam directly over pile and at the required frost depth. Individual pile caps also involve more formwork installation and really not that much saving in material.
RE: Grade Beam Question
