CSVGN1 generator dynamic model in EMTP
I am recreating the CSVGN1 static var compenator model from PSS/E into EMTP. The input to the block is the bus voltage and the putput is suscpetance B. I need to use this susceptance to vary the bus voltage depending on the change in the bus voltage according to reference voltage. How do I use the B in EMTP and change the bus voltage?
