under bench glasswasher - hood requirement
Hi, I've got an application where we are moving a couple of under bench glass washers within an existing building. They are approximately the same size as typical residential dishwashers and I was looking to treat them as such. Having reviewed the relevant code (IMC2012) I note that the code requires you to treat domestic style dishwashers as commercial type.
I feel it is ridiculous to provide a hood for an under bench dish/glass washer.
I see there appears to be a get-out-of-jail-free card in section 5.7.2.2 which basically says if the heat/moisture can be dealt with by the existing HVAC system you don't need a hood. Have other people used this clause?
Edit: note, there is no hood at the existing location
RE: under bench glasswasher - hood requirement
A small dish/glass wash isn't going to generate so much steam that the HVAC system can't handle it.
