Chasing a HVAC controller that is easy to operate!!!
I have been frustrated by the seeming lack of HVAC controllers which are easy to program and straight forward to use.
I am chasing something with a 7 day timer, which can operate a relatively simple setup of a couple of split AC units.
I am in the design field, and have had a number of clients say the controllers are too hard to use, but we have been unable to source any which do the job any easier.
Anyone with experience in this who has found something which works - I would love to hear from you.
RE: Chasing a HVAC controller that is easy to operate!!!
This is a very similar problem to the one I encountered. It is the modulating controls that are difficult to have in a small system. Maybe I was too general in my initial outline.
Also, the ability for the client to operate the system easily is important in this case, although I realise in most cases the above comments are correct.
Will approach the above companies and see if they can help. (Have already questioned Hevac, Honeywell & Trane to no avail).
Jmac.
I am not quite sure what you mean by "programmable." If it means a device that is programmed by setting a large nuimber of parameters, then I can't help you. Sorry. However, if you are looking for a controller like a PLC, that ships to you totally blank (does nothing when you plug it in), then I would recommend looking at CAREL. They have a controller called the PCO (pico) that comes in a variety of configurations, that can be programmed to do whatever you want. The programming is a little tricky, it is a graphical programming interface, but quite different from standard ladder relay logic. All of the PCO come with Analog and Digital I/O. Your garden variety PLC only come with Analog I/O at a premium price. THey also manufacture a wide range of temperature, pressure, and humidity probes, as well as fan speed controllers. There are built in functions for calculating wb and DP temps, and other HVAC calcs. The analog outputs are 0-10 VDC for controlling a valve, or you can get ones with an SSR output.
If you have to program it yourself, then you have to buy the software. That will make it expensive. But if this is something you can ujse more than once, then the one time expense is worth it.
I have used and programmed many of these controllers and have not come up against any HVAC application where I could not use this controller.
Check out www.carel.com or www.carelusa.com
Hope this helps.
Clyde
http://www.ies.invensys.com/pdf/MCS-4000.pdf
I have used it for years with very good results.
