Macro for Extract and Fill
Hey everybody,
i am new here and i hope, my question is in the right forum and i don't break any rules or something like that.
Like the topic said, i want to have a macro for catia that makes an extract and fill in the next step. The User should close holes with any structe in Partbodies. But if you have many holes
it should work faster, so with the macro will help to do it with just some clicks.
The idea is to do it this way:
1. User Selection which "Edge" should be extracted. Propagationtype is "point continuity".
- this type needs a support
2. User Selection for a "Face" that supports the extract.
(- here is the problem)
CODE --> CATvba
hybridShapeExtract1.Support = reference2
the whole code is following
3. the "Fill" takes the variable from the extract and choose it automatically
4. ask user if it's done or he wants to close another hole.
Until the special line everything works. But i don't understand why it stops there.
When i let this line out (with ') it works, but just with easy holes which don't need support.
I have recorded this Code and start to make it usefull for every partbody (individuel), but i have spend some hours with this mistake and i don't understand it.
Here is my Code:
CODE --> CATvba
'CLOSE SURFACE
Sub CATMain()
Dim partDocument1 As PartDocument
Set partDocument1 = CATIA.ActiveDocument
Dim part1 As Part
Set part1 = partDocument1.Part
Dim hybridShapeFactory1 As HybridShapeFactory
Set hybridShapeFactory1 = part1.HybridShapeFactory
Dim MyCatiaDocument As Document
Set MyCatiaDocument = CATIA.ActiveDocument
Dim MsgBoxReturn1 As VbMsgBoxResult
Set UserSel1 = MyCatiaDocument.Selection
'USERSELECTION EDGE
MsgBoxReturn = MsgBox("select edge", vbOKCancel, "Auswahl Edge")
If MsgBoxReturn = vbCancel Then
     MsgBox "Selection stops"
    Exit Sub
Else
    Dim InputObjectType1(0)
    InputObjectType1(0) = "Edge"
    UserSel1.Clear
    Dim Status1
    Status1 = UserSel1.SelectElement2(InputObjectType1, "select Edge ", False)
    End If
'EDGE [EXTRACT]
'CreatReferenceFromObject -> Edge
Dim reference1 As Reference
Set reference1 = UserSel1.Item2(1).Reference
Dim hybridShapeExtract1 As hybridShapeExtract
Set hybridShapeExtract1 = hybridShapeFactory1.AddNewExtract(reference1)
hybridShapeExtract1.PropagationType = 1 ' 1 = punktstetig
hybridShapeExtract1.ComplementaryExtract = False
hybridShapeExtract1.IsFederated = False
'USERSELECTION FACE
Dim MsgBoxReturn2 As VbMsgBoxResult
Set UserSel2 = MyCatiaDocument.Selection
MsgBoxReturn = MsgBox("select face", vbOKCancel, "Selection Face")
    Exit Sub
Else
    Dim InputObjectType2(0)
    InputObjectType2(0) = "Face"
    UserSel2.Clear
    Dim Status2
    Status2 = UserSel2.SelectElement2(InputObjectType2, "select face", False)
    End If
part1.Update
'FACE [EXTRACT]
'CreateReferenceFromGeometry -> Face
Dim reference2 As Reference
Set reference2 = UserSel2.Item2(1).Reference
'the reference needs to be included
'here is the special line, where everything stops
'hybridShapeExtract1.Support = reference2
Dim hybridBodies1 As HybridBodies
Set hybridBodies1 = part1.HybridBodies
Dim GeoSet As HybridBody
Set GeoSet = hybridBodies1.Add
GeoSet.Name = "Geometrical Set Close Surface"
Dim hybridBody1 As HybridBody
Set hybridBody1 = hybridBodies1.Item("Geometrical Set Close Surface") 'Speicherort des Extracts
hybridBody1.AppendHybridShape hybridShapeExtract1
part1.InWorkObject = hybridShapeExtract1
part1.Update
'FILL
'take reference/variable of boundary
Dim hybridShapeFill1 As HybridShapeFill
Set hybridShapeFill1 = hybridShapeFactory1.AddNewFill()
Dim reference3 As Reference
Set reference3 = part1.CreateReferenceFromObject(hybridShapeExtract1)
hybridShapeFill1.AddBound reference3
hybridShapeFill1.Continuity = 0
hybridBody1.AppendHybridShape hybridShapeFill1
part1.InWorkObject = hybridShapeFill1
part1.Update
'MSGBOX
'close the next hole? or ready and exit Macro
End Sub
thank you for every help.
if some other informations are needed, let me know it.
thumbsup
