Space between the roof and the ceiling
i have a question, is it required to put sprinklers below the roof? the situation will be an existing warehouse will be converted to an office building. there is a space [highlight #204A87]between the roof and the ceiling (just like an attic). thanks,
RE: Space between the roof and the ceiling
Will you be able to see the area between the office and roof deck?
Or is there a wall to block it ?
Also, if you "think" its not combustible, then it is, and sprinkler will be required.
In other words, substantiate.
FCU may or may not affect. Again, Chapter 8
R/
Matt
