zp: distance between the bolt line and the weld line
While I am using RAM connection standalone version 11.0.0.177 with (EN 1993-EC3) i noticed that there is a value called Zp it is the distance between the bolt line and the weld line but while I am using beam to girder connection this value is taken as the distance between the bolt line and the outer edge of the girder as shown in snap below:
My question is why this distance is from the bolt line and the outer edge of the girder?
first i thought that the program will add the Zp to half of girder flange but this has not happened
there is a similar case in AISC and they assume that the distance as below:
