Copy sketch with link to another part
i'm used to CATIA, but now i'm doing a few works in SW.
I'm trying to copy a sketch from one part to another, but i want the the copied sketch maintains a link to the geometry of the first one. In catia i can past the sketch with link. Then everything that i make to the first sketch will update to the copied one. How can i do it in SW.
RE: Copy sketch with link to another part
I believe it is, but if I change the geometries of the first sketch, the one that has the geometries with the convert entities will not update, or am I wrong?
Chris, CSWP
SolidWorks '16
ctophers home
SolidWorks Legion
Jeff Mirisola, CSWE
My Blog
If you want to use a sketch as part of a master model, then copy the master sketch parts in context to a component using Convert Entities, as was suggested.
Patrick
