Name of 2nd time derivative of charge q?
For charge q, the first time derivative dq/dt is the current i. The 2nd time derivative is d^2q/dt^2. Is there a name for this?
By analogy, for a mechanical system the displacement is u and the first time derivative du/dt is the velocity. The 2nd time derivative d^2u/dt^2 is the acceleration.
Don C.
Don C.
RE: Name of 2nd time derivative of charge q?
xnuke
"Live and act within the limit of your knowledge and keep expanding it to the limit of your life." Ayn Rand, Atlas Shrugged.
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
TTFN
FAQ731-376: Eng-Tips.com Forum Policies forum1529: Translation Assistance for Engineers
The 2nd time derivative of charge is used for the voltage drop across an inductor -- V = L d^2q/dt^2 = L di/dt. I'd like to refer to this derivative textually in the same manner as one would refer to "acceleration" (i.e., without having to continually refer "2nd time derivative of charge" or "2nd time derivative of displacement").
Yes, I forgot about that. But, that's just referred to as "ell dee eye dee tee" and there is no specific physics symbol for that quantity, so no name either.
TTFN
Electrical engineering doesn't have position, velocity, accelleration, but we're just jerks. [bigsmile]
Bill
"Why not the best?"
Jimmy Carter
"Current rate of change" is the only name that I recall.
As you mention in mechanical systems there is position, velocity, acceleration, jerk, and Ping.
