Hide sketch expressions in NX9
I am modelling a component with geometry that is associated with other line lengths.
Is it possible to hide the formula in the displayed dimension and instead show the parameter number and value?
For example:
p28 = 40
p29 = 10
p30 = p28+2*p29 > > INSTEAD > > p30 = 60
Thanks in advance,
Christopher Swain
For example:
p28 = 40
p29 = 10
Thanks in advance,
Christopher Swain
RE: Hide sketch expressions in NX9
You can modify it in File/Preferences/All preferences/Sketch/sketch settings/dimension label/Value
Airin
NX Designer
That doesn't allow you to see the parameter number though does it?
I was hoping there was a way to display the value and parameter name.
Any further thoughts?
Kind Regards,
Chris
