*Node print, freq=1,nset=SET-17 LE.E11,LE.E22,S.S11,S.S22
Hello ^lease i am using abaqus with matlab i would like to compare experimental data and numerical data from abaqus so i must use the .unp file. Ihave a question i must write in the buttom
Node Output
RF, U
*Element Output, directions=YES
E, MISES, S
** HISTORY OUTPUT: H-Output-1
Output, history, variable=PRESELECT
*End Step
is it possible to do this please i need your help
RE: *Node print, freq=1,nset=SET-17 LE.E11,LE.E22,S.S11,S.S22
Strains and stresses are element results (from integration points) and cannot be used with *Node Print.
You can use the postprocessing in A/CAE with the report to get extrapolated and averaged element results at nodes written into a txt-file..
