2/3 Rule for Heat Exchangers
Can someone tell me if this rule still applies? I have heard that there has been an update to the rule, however that's all I know. If anyone can shed some light on this topic it would be greatly appreciated.
Bluemax89
Bluemax89
RE: 2/3 Rule for Heat Exchangers
All, the rule applies to the entire system including upstream and downstream piping that would be pressurized to the tube rupture pressure (whatever you work that out to be), you can't just stop at the exchanger's flanges and ignore everything else.
The more you learn, the less you are certain of.
