Error reading journal - Keyboard Shortcut
I have a journal as user command and I want to use a keyboard shortcut key with it but, once set-up the keyboard shortcut, a message show up:
"Error reading Journal, C:\Users|User1\Journal.vb, File open failed".
Some code lines are needed in the journal or fix some settings?
Best Regards
RE: Error reading journal - Keyboard Shortcut
DavidQ,
The text in the posting appears to suggest that the command definition may have a typographical error.
The directory separator between "Users" and "User1" appears to be the result of unintended uppercase for the
was probably meant to be
C:\Users\User1\Journal.vb
Regards, Joe
If you run it without the shortcut, and browse to the file, does that work?
Menu > Tools > Journal > Play
Mark Rief
NX CAM Customer Success
Siemens PLM Software
Hello markrief,
Yes, it works fine if I browse to the file and using a customize button.
Best Regards
I'm using NX9.0.3.4.
Tools > Customize > Commands Tab > Keyboard... From Customize Keyboard, Specify a command, Categories:
Scroll all the way down to My Buttons > My User Commands, from Commands select journal, Press new shortcut key.
