ANSYS modelling of steel beam-column connection
Are there any tutorials to perform modal analysis of a simple steel beam-column connections in ANSYS? I only want to model the beam-column connection or a frame and not the entire structure. When doing this, since the mass is less, the frequency will be very high and the period very low, what is the solution for this? Thanks!
