Drawing Wire Out of LEMO Connector
Hello Everybody,
I have a LEMO B type connector (FGG.0B). This is the first time I am working this, so my question is quite basic. How do I connect the wires to the pins, which are in the shape of the eyebrow or half moon shaped. I have read a ew instruction in below link, however it does not explicitly talks about soldering, however there are certain parameters mentioned for the soldering.
http://intra.lemo.ch/acctools/B-series-assembly-in...
Thanks and I appreciate your help,
Padmanapan
RE: Drawing Wire Out of LEMO Connector
That connector has either crimp or solder contacts..
Which did you get?
I am pretty sure it is a soldering contact after going through slide# 11 in the website http://dkc1.digikey.com/us/en/tod/lemo/b-series_no..., from where I have also uploaded an Image. It calls it as a soldering joint, so I assume it needs to be soldered.
Is there a specific way to solder this contact, could please suggest me link I can look for soldering methods for this, or it is just the conventional way.
Thanks once again
Padmanapan
Thanks a lot!
