Reactions at plates corners vs. bolt group analysis?
To all,
If one considers a standard bolt group analysis (say a square pattern in the XY plane) with an applied load (Fx) at the centre of the bolt group
Shear force/bolt = Fx/4
If one however considers a square plate with full constraints at its 4 corners and a load in the x direction then one gets the reaction Rx = (-) Fx/4 but one also gets Fy reactions
Which method should one be inclined to "believe" if one was interested in the reactions (at the bolts)?
With the 2nd method one gets the stiffness effect of the plate and the fy load are the loads to stop the plate "shrieking" but one can get quite some high forces
RE: Reactions at plates corners vs. bolt group analysis?
I'm not 100% clear on what you are trying to do, but if you want to draw a picture and add a few more specific questions, I'm sure you'll get some better responses.
