Techinical Specifications of Hand Shears
Hi. Can someone please explain the technical specifications mentioned in the attachment? Thank you. The tool is a hand shear. I understand 2 of the 5 only. First shows thickness that can be cut, and fourth shows length of cut. But, don't understand 2nd, 3rd and 5th. Rich
RE: Techinical Specifications of Hand Shears
Why not call/email the manufacturer and ask them?
Probably an overseas, Chinese-copy of a market item sold by an import shop.
Disagree there. For model 140759 (right hand column).
1. Max thickness of the plate (square bar) 1/4 inch.
2. Probably maximum plate size (flat bar ?)
3. Max rod diameter
4. Max plate width (width that the machine can fit in the jaws, regardless of how thick it is.
5. Not sure.
