Aboveground gas pipeline
Dear pipelinerS and other,
I would like to ask you people, I've seen there are gas pipeline aboveground in the tropic area(warmth climate area). What is the main reason or main issue to choose this way ? As far as I know, some reason for aboveground pipeline are for geothermal service, or pipeline that would be build in subtropic and cold climate.
Anybody could give me enlighten ?
RE: Aboveground gas pipeline
Most pipelines are buried in public areas for security, safety, access across them and reduced cost.
Very vague question so a very vague answer.
There are 2 type soil ground where the pipeline i've seen. The first half is usual soil&clay and the half way is siltysoil/swamp. So it's make me wonder, why the company allowed to apply aboveground pipeline.
According to your opinion, is there any clue or other issued that can you guess why this aboveground applied ?
when you say "above ground", do you mean just laid on the surface or actually on properly prepared supports? Plastic or steel? More than one? Big or small? Low or high pressure? distance from the road?
With no description, no photos, no details ( size, pressure, length, number of people around etc), there's not much more to say.
