Journal Export DXF and PDF
Hi All,
I've been looking into programming a journal to export a dxf and a pdf from a drawing.
I'm using the stand alone draft method (draft and model are one file)
The program code attached is ok regarding the pdf export part. De dxf export part is not ok. The dxf export is the export of the flat pattern in the model. When no flat pattern (sheet metal) is available only a warning should be given that no dxf is exported.
Since i'm no programming expert (far from) i'm looking for someone the pick out the bugs from my program.
Kind regards,
Lars
Lars
Solid Edge
Inventor
NX10.0.3.5 native
RE: Journal Export DXF and PDF
Hi Lars,
You don't describe you actual problem in enough detail to advise on what may be the problem.
I have no experience with the exportFlatPatternBuilder1 but you can also get a dxf by exporting the drawing sheet. The following is some working C# code that does that using the NXOpen DxfdwgCreator class.
Paul
CODE --> C#
// Export Specified Drawing Sheet to ACAD/DWG Format
        private static int ExportDrawingSheetToDxf(DrawingSheet aSheet, string aOutputFileName, Part aInputPart)
            if (!ProjectSystemIO.CheckWritableFile(aOutputFileName))
                return 1;
            string dxfSettingsDir = NXProgramClass.Session.GetEnvironmentVariableValue("DXFDWG_DIR");
            string DxfdwgDir = NXProgramClass.Session.GetEnvironmentVariableValue("DXFDWG_DIR");
            if(String.IsNullOrEmpty(dxfSettingsDir))
                MessageBox.Show("DXF settings directory not found; journal exiting.",
                    "DXF settings error", MessageBoxButtons.OK, MessageBoxIcon.Error);
                return 1;
            if(String.IsNullOrEmpty(DxfdwgDir))
                MessageBox.Show("Dxfdwg settings directory not found; journal exiting.",
                    "Dxfdwg settings error", MessageBoxButtons.OK, MessageBoxIcon.Error);
                return 1;
            DxfdwgCreator dxfdwgCreator1;
            dxfdwgCreator1 = NXProgramClass.Session.DexManager.CreateDxfdwgCreator();
            dxfdwgCreator1.SettingsFile = ProjectSystemIO.PathCombine(dxfSettingsDir, "dxfdwg.def");
            dxfdwgCreator1.InputFile = aInputPart.FullPath;
            dxfdwgCreator1.OutputFile = aOutputFileName;
            dxfdwgCreator1.DrawingList = aSheet.Name;
            dxfdwgCreator1.AutoCADRevision = DxfdwgCreator.AutoCADRevisionOptions.R2000;
            dxfdwgCreator1.ExportData = DxfdwgCreator.ExportDataOption.Drawing;
            dxfdwgCreator1.OutputFileType = DxfdwgCreator.OutputFileTypeOption.Dxf;
            dxfdwgCreator1.ObjectTypes.Curves = true;
            dxfdwgCreator1.ObjectTypes.Annotations = true;
            dxfdwgCreator1.ObjectTypes.Structures = true;
            dxfdwgCreator1.FlattenAssembly = false;
            dxfdwgCreator1.ViewEditMode = false;
            dxfdwgCreator1.FileSaveFlag = false;
            dxfdwgCreator1.LayerMask = "1-256";
            dxfdwgCreator1.DrawingList = "";
            dxfdwgCreator1.ViewList = "TOP,FRONT,RIGHT,BACK,BOTTOM,LEFT,TFR-ISO,TFR-TRI";
            NXObject nXObject1;
            nXObject1 = dxfdwgCreator1.Commit();
            dxfdwgCreator1.Destroy();
            // presume no other errors
            return 0;
Paul Turner
CAD & Process Engineer
Mastip Technology
[b]Hi Paul,
Thanx for the response. The thing is that i'd really like to use the flat pattern export out of the model environment.
This because of the layer settings etc.
The shop i work for outsources al it's sheet metal production. They must have a dxf for laser cutting and bending and also a PDF to make sure no faults are made converting the dxf.
I've found two program's i think i can combine into one program.
Ik want to start this program out of the drafting environment and first make the pdf. Then the program has to switch into de sheet metal environment and export the flat pattern.
The location of the output files will have to be the same as the location of the prt file.
Thats all i want to do. Problem is that de PDF works ok. And the flat pattern also works (with a set flat pattern name).
When i try to inbed a piece of program which finds the flat pattern I get faults.
Kind Regards,
lars
Lars
Solid Edge
Inventor
NX10.0.3.5 native
Here's some code to try:
CODE
Option Strict Off
Imports System
Imports System.Collections.Generic
Imports NXOpen
Imports NXOpen.UF
Module Module1
    Dim theSession As Session = Session.GetSession()
    Dim theUfSession As UFSession = UFSession.GetUFSession()
    Dim workPart As Part = theSession.Parts.Work
    Dim lw As ListingWindow = theSession.ListingWindow
    Sub Main()
        Dim currentPath As String = GetFilePath()
        Dim currentFile As String = GetFileName()
        Dim pdfFile As String = GetFilePath() & GetFileName() & ".pdf"
        Dim dxfFile As String = GetFilePath() & GetFileName() & ".dxf"
        Dim partUnits As Integer = theSession.Parts.Display.PartUnits
        '0 = inch
        '1 = metric
        Dim i As Integer = 0
        For Each sheet As Drawings.DrawingSheet In theSession.Parts.Display.DrawingSheets
            'msgbox (sheet.name)
            i = i + 1
            Try
                ExportPDF(sheet, pdfFile, partUnits)
            Catch ex As Exception
                MsgBox("Error occurred in PDF export" & vbCrLf & ex.Message & vbCrLf & "journal exiting", vbCritical + vbOKOnly)
                Exit Sub
            End Try
        Next
        If i = 0 Then
            msgbox("This part has no drawing sheets to export")
        Else
            msgbox("Exported: " & i & " sheet(s) to pdf file" & vbcrlf & pdfFile, vbokonly + vbinformation)
        End If
        Dim myFlatPattern As Features.FlatPattern = GetFlatPattern()
        If IsNothing(myFlatPattern) Then
            'skip it
            'warn user?
        Else
            'export flat pattern to dxf
            lw.WriteLine("exporting dxf to: " & dxfFile)
            ExportFlatPattern(myFlatPattern, dxfFile)
        End If
    End Sub
    Function GetFlatPattern() As Features.FlatPattern
        If IsNothing(theSession.Parts.Work) Then
            'active part required
            Return Nothing
        End If
        For Each myFeature As Features.Feature In workPart.Features
            If TypeOf (myFeature) Is Features.FlatPattern Then
                Return myFeature
            End If
        Next
        'if we make it here, no flat pattern was found
        Return Nothing
    End Function
    Sub ExportFlatPattern(ByVal theFlatPattern As Features.FlatPattern, ByVal outputFile As String)
        Dim exportFlatPatternBuilder1 As NXOpen.Features.SheetMetal.ExportFlatPatternBuilder
        exportFlatPatternBuilder1 = workPart.Features.SheetmetalManager.CreateExportFlatPatternBuilder()
        exportFlatPatternBuilder1.AddedTop = True
        exportFlatPatternBuilder1.AddedBottom = True
        exportFlatPatternBuilder1.DxfRevision = NXOpen.Features.SheetMetal.ExportFlatPatternBuilder.DxfRevisionType.R14
        exportFlatPatternBuilder1.OutputFile = outputFile
        exportFlatPatternBuilder1.FlatPattern.Value = theFlatPattern
        Dim nXObject1 As NXOpen.NXObject
        nXObject1 = exportFlatPatternBuilder1.Commit()
        exportFlatPatternBuilder1.Destroy()
    End Sub
    Function GetFileName()
        Dim strPath As String
        Dim strPart As String
        Dim pos As Integer
        'get the full file path
        strPath = theSession.Parts.Display.FullPath
        'get the part file name
        pos = InStrRev(strPath, "\")
        strPart = Mid(strPath, pos + 1)
        strPath = Left(strPath, pos)
        'strip off the ".prt" extension
        strPart = Left(strPart, Len(strPart) - 4)
        GetFileName = strPart
    End Function
    Function GetFilePath()
        Dim pos As Integer
        GetFilePath = strPath
    End Function
    Sub ExportPDF(dwg As Drawings.DrawingSheet, outputFile As String, units As Integer)
        Dim printPDFBuilder1 As PrintPDFBuilder
        printPDFBuilder1 = workPart.PlotManager.CreatePrintPdfbuilder()
        printPDFBuilder1.Scale = 1.0
        printPDFBuilder1.Colors = PrintPDFBuilder.Color.BlackOnWhite
        printPDFBuilder1.Size = PrintPDFBuilder.SizeOption.ScaleFactor
        If units = 0 Then
            printPDFBuilder1.Units = PrintPDFBuilder.UnitsOption.English
        Else
            printPDFBuilder1.Units = PrintPDFBuilder.UnitsOption.Metric
        End If
        printPDFBuilder1.XDimension = dwg.height
        printPDFBuilder1.YDimension = dwg.length
        printPDFBuilder1.OutputText = PrintPDFBuilder.OutputTextOption.Polylines
        printPDFBuilder1.RasterImages = True
        printPDFBuilder1.ImageResolution = PrintPDFBuilder.ImageResolutionOption.High
        printPDFBuilder1.Append = False
        printPDFBuilder1.Watermark = ""
        Dim sheets1(0) As NXObject
        Dim drawingSheet1 As Drawings.DrawingSheet = CType(dwg, Drawings.DrawingSheet)
        sheets1(0) = drawingSheet1
        printPDFBuilder1.SourceBuilder.SetSheets(sheets1)
        printPDFBuilder1.Filename = outputFile
        Dim nXObject1 As NXObject
        nXObject1 = printPDFBuilder1.Commit()
        printPDFBuilder1.Destroy()
    End Sub
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        'Unloads the image immediately after execution within NX
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
    End Function
End Module
www.nxjournaling.com
Cowski,
It works like a charm. Thanx a lot
bigsmile
Kind regards,
Lars
Lars
Solid Edge
Inventor
NX10.0.3.5 native
Hi Lars,
Thanks for sharing.
I tried to use above code from cwoski in NX6, with errors attached to the post
I was trying to export dxf from a sheetmetal part in NX using the above journal, Need help to use the progm.
Subhash
Regards / Freundliche Grn¯e / Cordialement,
Subhash Madkatte
SIEMENS | I BT LV GC | R & D | Mumbai | India.
E-mail:subhash.madkatte@siemens.com; madkatte@gmail.com
madaktte,
The journal was written for NX 9/10; it makes use of at least one function that is not available in NX 6. It will probably work in NX 8, but will not work in any version before 8.
Hi Cowski,
Thanks for the info.
Hope to get NX9 soon :) & use this journal.
Subhash Madkatte
Cowski,
The journal mentioned above works like a charm as I said.
The only thing that the journal is not doing, is exporting all the draft sheets.
The journal now only makes a PDF of the last sheet.
I've tweaked the journal a bit with the msgbox filling but don't see why that should affect the export of the draft to PDF.
The idea is that the exported PDF is one file containing als sheets.
Can this be done ?
Lars
Lars
Solid Edge
Inventor
NX10.0.3.5 native
Try changing this line in the ExportPDF sub:
CODE
printPDFBuilder1.Append = False True
Cowski,
it works. Thnx a lot.
Lars
Lars
Solid Edge
Inventor
NX10.0.3.5 native
Cowski,
I said it was alright but the following happens now.
When I save the pdf and anPDF from this file is already exists, the sheets are added to this PDF. This causing errors and mistakes.
A simple question from windows to overwrite the existing (PDF) file or not should be sufficient to make sure no double data is made.
Can this be added to the current code ?
Kind regards,
Lars
Lars
Solid Edge
Inventor
NX10.0.3.5 native
Try changing Sub Main to the following:
CODE
Sub Main()
        '0 = inch
        '1 = metric
            i = i + 1
            'the pdf export uses 'append file', if we are on sheet 1 make sure the user wants to overwrite
            'if the drawing is multisheet, don't ask on subsequent sheets
            If i = 1 Then
                If IO.File.Exists(pdfFile) Then
                    Dim rspFileExists As Windows.Forms.DialogResult
                    rspFileExists = Windows.Forms.MessageBox.Show("The file: '" & pdfFile & "' already exists; overwrite?", "Overwrite file?", Windows.Forms.MessageBoxButtons.YesNo, Windows.Forms.MessageBoxIcon.Question)
                    If rspFileExists = Windows.Forms.DialogResult.Yes Then
                        Try
                            IO.File.Delete(pdfFile)
                            Windows.Forms.MessageBox.Show(ex.Message & vbCrLf & "Journal exiting", "Error", Windows.Forms.MessageBoxButtons.OK, Windows.Forms.MessageBoxIcon.Error)
                            Exit Sub
                        End Try
                    Else
                        'user chose not to overwrite file
                        'msgbox("journal exiting", vbokonly)
                        Exit Sub
                    End If
                End If
            End If
            Try
                Exit Sub
            End Try
        Next
        If i = 0 Then
        Else
        End If
            'skip it
            'warn user?
            lw.WriteLine("flat pattern is nothing")
        Else
        End If
    End Sub
Try fully qualifying all the references to Windows.Forms
i.e. change all the lines like
CODE
Windows.Forms...
to:
CODE
System.Windows.Forms...
Ok thnx.
Works :)
Lars
Lars
Solid Edge
Inventor
NX10.0.3.5 native
Cowski,
The journal jou made works great thnx a lot for this help.
As you probably guessed ....I have a question bigsmile.
The automatic export of PDF and Flat pattern works great when using stand alone parts. But when I have a master model setup only the PDF is made. The flat pattern isn't exported?
I'de like to add a few lines of code which get the flat pattern out of the component linked to the draft.
Kind Regards,
Lars
Lars
NX10.0.3.5 native
Solid Edge
Inventor
Anybody?
Lars
NX10.0.3.5 native
Solid Edge
Inventor
CODE
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module Module3
    Sub Main()
        lw.Open()
        '0 = inch
        '1 = metric
            i = i + 1
            If i = 1 Then
                    Dim rspFileExists As System.Windows.Forms.DialogResult
                    rspFileExists = System.Windows.Forms.MessageBox.Show("The file: '" & pdfFile & "' already exists; overwrite?", "Overwrite file?", System.Windows.Forms.MessageBoxButtons.YesNo, System.Windows.Forms.MessageBoxIcon.Question)
                    If rspFileExists = System.Windows.Forms.DialogResult.Yes Then
                        Try
                            System.Windows.Forms.MessageBox.Show(ex.Message & vbCrLf & "Journal exiting", "Error", System.Windows.Forms.MessageBoxButtons.OK, System.Windows.Forms.MessageBoxIcon.Error)
                            Exit Sub
                        End Try
                    Else
                        Exit Sub
                    End If
                End If
            End If
            Try
                Exit Sub
            End Try
        Next
        If i = 0 Then
            MsgBox("This part has no drawing sheets to export")
        Else
            MsgBox("Exported: " & i & " sheet(s) to pdf file" & vbCrLf & pdfFile, vbOKOnly + vbInformation)
        End If
        Dim myFlatPattern As Features.FlatPattern = Nothing
        Dim c As Assemblies.ComponentAssembly = theSession.Parts.Display.ComponentAssembly
        If IsNothing(c.RootComponent) Then
            'Part has no components, look for flat pattern in this part
            lw.WriteLine("part has no components, looking for flat pattern in this file")
            myFlatPattern = GetFlatPattern(theSession.Parts.Display)
        End If
        If c.RootComponent.GetChildren.Length > 1 Then
            'this is an assembly, not a drawing file
            lw.WriteLine("part is not a drawing (it has more than one component), exiting")
            Exit Sub
        End If
        'lw.WriteLine("display part has one component")
        'lw.WriteLine("display part has " & c.RootComponent.GetChildren(0).GetChildren.Length.ToString & " grandchildren")
        If c.RootComponent.GetChildren(0).GetChildren.Length <> 0 Then
            'child component is a subassembly
            Exit Sub
        End If
        If Not LoadComponent(c.RootComponent.GetChildren(0)) Then
            'component not fully loaded, will not be able to access flat pattern feature info
            Exit Sub
        End If
        myFlatPattern = GetFlatPattern(c.RootComponent.GetChildren(0).Prototype.OwningPart)
            'skip it
            'warn user?
        Else
        End If
        lw.Close()
    End Sub
    Function GetFlatPattern(ByVal thePart As Part) As Features.FlatPattern
        If IsNothing(thePart) Then
            'part required
            Return Nothing
        End If
        For Each myFeature As Features.Feature In thePart.Features
                Return myFeature
            End If
        Next
        Return Nothing
    End Function
        exportFlatPatternBuilder1.Type = Features.SheetMetal.ExportFlatPatternBuilder.FileType.Dxf
    End Sub
        Dim pos As Integer
    End Function
        Dim pos As Integer
    End Function
        If units = 0 Then
        Else
        End If
        printPDFBuilder1.XDimension = dwg.Height
        printPDFBuilder1.YDimension = dwg.Length
        printPDFBuilder1.Append = True
    End Sub
    Private Function LoadComponent(ByVal theComponent As Assemblies.Component) As Boolean
        Dim thePart As Part = theComponent.Prototype.OwningPart
        Dim partName As String = ""
        Dim refsetName As String = ""
        Dim instanceName As String = ""
        Dim origin(2) As Double
        Dim csysMatrix(8) As Double
        Dim transform(3, 3) As Double
        Try
            If thePart.IsFullyLoaded Then
                'component is fully loaded
            Else
                'component is partially loaded
            End If
            Return True
        Catch ex As NullReferenceException
            'component is not loaded
            Try
                theUfSession.Assem.AskComponentData(theComponent.Tag, partName, refsetName, instanceName, origin, csysMatrix, transform)
                Dim theLoadStatus As PartLoadStatus
                theSession.Parts.Open(partName, theLoadStatus)
                '_theUfSession.Assem.SetAssemOptions(curLoadOptions)
                If theLoadStatus.NumberUnloadedParts > 0 Then
                    Dim allReadOnly As Boolean = True
                    For i As Integer = 0 To theLoadStatus.NumberUnloadedParts - 1
                        If theLoadStatus.GetStatus(i) = 641058 Then
                            'read-only warning, file loaded ok
                        Else
                            '641044: file not found
                            allReadOnly = False
                        End If
                    Next
                    If allReadOnly Then
                        Return True
                    Else
                        'warnings other than read-only...
                        Return False
                    End If
                Else
                    Return True
                End If
            Catch ex2 As NXException
                Return False
            End Try
        Catch ex As NXException
            'unexpected error
            Return False
        Finally
        End Try
    End Function
    End Function
End Module
